Misa23
Oct 15, 2023Aspirant
How to connect my R6300 using my mobile device as hotspot?
Dear all I am wondering how I connect my (old but excellent) R6300 Netgear using my iPhone as a hotspot: My iPhone hotspot ---> connecting to Netgear R6300 (instead the usual lan cables) ...
- Oct 16, 2023
If the router has a wires bridge mode, then you could connect it to your phone wifi hot spot signal as a wireless client then you could use the LAN ports in back for wired devices. If the router doesn't then no, the router you have won't work.
Oct 16, 2023Guru - Experienced User
Misa23
Oct 19, 2023Aspirant
Thanks a lot for your input!
