indrakumar
Nov 27, 2016Follower
How to connect two wnr614 together
How to connect the two wnr614 together. iam not using internet connection
- Nov 28, 2016
Welcome to the community, indrakumar
What are you trying to achieve in connecting this two routers together?
You can set it up as a wireless Access Point by disabling the DHCP and then connect the first router to one of the LAN ports on the second router.
Or you may have 2 networks by leaving the DHCP on, enable Static Routing and connect the first router to the WAN port on the second router.
ElaineM
Nov 28, 2016NETGEAR Employee Retired
