NemishMehta
May 28, 2021Aspirant
How to convert my netgear router to a range extender
Hi I have a Jio Fiber connection which uses an JCO4032 router, i would like to convert my netgear R6220 router as a range extender and connect to my jio router wirelessly. Please let me know if t...
NemishMehta
May 31, 2021Aspirant
Thanks for the info, but the problem i am facing is that my base station is not a netgear router and was looking at an option if i can setup a connection between both of them using a wps option or any other option where my netgear router connects to the wifi in my home.
Regards
Nemish
michaelkenward
Jun 01, 2021Guru - Experienced User
NemishMehta wrote:
.... the problem i am facing is that my base station is not a netgear router and was looking at an option if i can setup a connection between both of them using a wps option or any other option where my netgear router connects to the wifi in my home.
The brand does not matter. WPS is an industry standard. That's why you can use WPS to connect a printer for a phone to the wifi on a router. (Netgear doesn't make printers, or phones.) The R6220 supports WPS for those things.
The first question is does the R6220 work as a repeater? That's what plemans referred to.
As a basic device, it does not seem to. If it does, then plemans has told you where to find advice on setting it up.
The manual shows that you can Use the Router as a Wireless Access Point.
