008MB
Aug 27, 2020Aspirant
How to Disable remote login
I can't seem to disable remote login to admin. i.e. using my phone with wifi on I can login to admin via 192.168.1.1 shouldn't i be able to disable this access? Mike
- Aug 27, 2020
the 192.168.1.1 isn't remote access. Its local access meaning on your network.
Remote access is access external to your network.
Aug 27, 2020Guru - Experienced User
- 008MBAug 27, 2020Aspirant
Right, I mistakenly said "Remote Access"
I have a linksys router and I can block admin access via wifi, so, how do I do this on the R6230?
Mike
- antinodeAug 27, 2020Guru
> I have a linksys router [...]
Thanks for the detailed description.
> [...] and I can block admin access via wifi, so, how do I do this on
> the R6230?Not an option which I've seen on any Netgear router. The "admin"
password is the only restriction I've seen.
