008MB
Aug 27, 2020Aspirant
How to Disable remote login
I can't seem to disable remote login to admin. i.e. using my phone with wifi on I can login to admin via 192.168.1.1 shouldn't i be able to disable this access? Mike
- Aug 27, 2020
the 192.168.1.1 isn't remote access. Its local access meaning on your network.
Remote access is access external to your network.
antinode
Aug 27, 2020Guru
> Model: R6230|AC1200 Smart WiFi Router Dual Band Gigabit
Is that accurate? Firmware version?
> with wifi on I can login to admin via 192.168.1.1 [...]
Define "remote".
What makes you think that your "my phone" is "remote" when you're
"using my phone with wifi"? Or that any "remote" device could
communicate with your router at a private address like "192.168.1.1"?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Remote
Management".
Then, using your cellular-telephone data connection rather than a
wireless connection to your own router, try again.
