008MB's avatar
008MB
How to Disable remote login
I can't seem to disable remote login to admin.  i.e.  using my phone with wifi on I can login to admin via 192.168.1.1    shouldn't i be able to disable this access? Mike
  • plemans's avatar
    Aug 27, 2020
    the 192.168.1.1 isn't remote access. Its local access meaning on your network.
    Remote access is access external to your network.
