richard42ack
Dec 12, 2020Guide
How to download readyshare files using python
From a browser, I am able to access both directory listings and file contents. Using the python requests library, I am able to list the directory on readyshare. However, I have not been able to ...
antinode
Dec 12, 2020Guru
> Model: AC2100|Nighthawk AC2100 Smart WiFi Router
Firmware version? Connected to what?
> From a browser, [...]
Which? Running on what? Which is connected how to what?
> Using the python requests library, [...]
> [...]_title_ NETGEAR Router WAC124_/title_[...]
Have you any idea why an AC2100 would put a title tag in its response
which included _that_ (different) model number? At least one of us
seems to be confused.
If I had multiple Netgear routery devices on my LAN, and I wanted to
deal with a particular one of them, then I might specify its LAN IP
address rather than any "routerlogin" name.
> # (headers not shown, but were set to same as the ones used by the
> browser)
"headers"? (Do I care?)
richard42ack
Dec 12, 2020Guide
Never mind I have solved it.
Make the call to the file a second time and it returns the file.
To answer questions:
1. This is wrt readyshare, which is similar on various netgear products but seems to have no documentation about how they work.
2. You might not care, but it is quite often the case that the server will. By providing the same headers as the browser, we eliminate that as an issue.
3. I had forgotten which of my routers was the one with the usb -- and didn't give it a whole lot of attention when filling out the item they asked for -- it is after all, mostly a software issue, not a hardware one.
- richard42ackDec 12, 2020Guide
