Birdo
Jun 26, 2017Aspirant
How to find the router firmvare Version?
There are notes on this Forum that Netgear has updated "from the WEB" the firmware of some WNR2000v3 routers to the last and necessary version 1.1.2.14 so that the users do NOT need to do any update ...
- Jun 27, 2017
Birdo wrote:
With a wired (Ethernet) to my DELL desktop and Win 10 when a enter the 192.168.1.1. address I get a long list of links to articles by various (some questionable) sources but NOT a place where I can see a request for my user name and pass.
That address is a local one. It is on your network. It is not somewhere out in the Internet.
You should not need to go to 192.168.1.1
Did you try the other links?
http://www.routerlogin.com/
or
http://www.routerlogin.netJust click them. They are also local addresses, so no risk of nasties. They are Netgear's way of making it "easier" to get your browser to control your router.
William10a
Jun 26, 2017Master
I know this manual is the version 2 manual and you have the version 3 but it is much clear in what you need to do to update the router automatic or manual starts page 113.
http://www.downloads.netgear.com/files/GDC/WNR2000V2/WNR2000v2_UM_15JAN2010.pdf
Just make sure you use correct firmware when updating.
Here is the latest firmware update forthe wnr2000v3 https://www.netgear.com/support/product/WNR2000v3.aspx#download
