Birdo
Jun 26, 2017Aspirant
How to find the router firmvare Version?
There are notes on this Forum that Netgear has updated "from the WEB" the firmware of some WNR2000v3 routers to the last and necessary version 1.1.2.14 so that the users do NOT need to do any update ...
- Jun 27, 2017
Birdo wrote:
With a wired (Ethernet) to my DELL desktop and Win 10 when a enter the 192.168.1.1. address I get a long list of links to articles by various (some questionable) sources but NOT a place where I can see a request for my user name and pass.
That address is a local one. It is on your network. It is not somewhere out in the Internet.
You should not need to go to 192.168.1.1
Did you try the other links?
http://www.routerlogin.com/
or
http://www.routerlogin.netJust click them. They are also local addresses, so no risk of nasties. They are Netgear's way of making it "easier" to get your browser to control your router.
Birdo
Jun 27, 2017Aspirant
William10a wrote:If using a wired lan cable to connect your computer to the router you will need to use a web browser and go to the ip address 192.168.1.1, you should see a request for your user's name and password
William:
May you try yourself this 192.168.1.1. link and explain why I get a different (if so) result.
With many thanks
michaelkenward
Jun 27, 2017Guru - Experienced User
or
- William10aJun 27, 2017Master
192.168.1.1 is the just the way I perfer to access the router login page since it is standard across a wide range of brands of routers both ways get you the same place on your router.
- michaelkenwardJun 27, 2017Guru - Experienced User
I like to keep things as simple as possible. Most users do not know, or care, about different brands. They just want easy access to their controls.
That is why I also suggest using Netgear's desktop genie. Propeller heads may find it frustrating, but used properly it does a good job for mere mortals.
- BirdoJun 27, 2017Aspirant
Michaelkenward:
MY HEARTIEST THANKS!!!
HURRAH!!! The router is now updated and working!!!
The http://www.routerlogin.com DID give the LogIn page (All other links did not).
Working as a Blindfolded in a labyrinth I managed to get through to the working new 1.1.2.14 version.
Many Thanks again
