vgear's avatar
vgear
Follower
Dec 05, 2023
How to get "†Up to 750Mbps wireless speeds..." on Night Hawk R6020
The AC740 retail box and data sheet mention speeds of 300, 450 & 750Mbps, but since the ethernet ports are only10/100, HOW do you connect it so it achieves those speeds? Other discussions asked how to use it connected wirelessly, but community only came up with ethernet connection which couldn't.
Data Sheet | R6020 AC750 Dual Band WiFi Router
Performance & Use
•AC750 WiFi - speeds up to 300+450Mbps†
Up to 750Mbps wireless speeds achieved when connecting to other 802.11ac 750Mbps devices
1 Reply
  • Those speeds are between two WiFi clients transferring data, not WiFi <=> LAN. The speeds are also in ideal, controlled conditions. In reality, it's always less than.
