sdbowe33
May 17, 2018Aspirant
How to increase speed?
My modem supports 100 mbps. However, the AC1450 smart wifi router is only distributing 20 mbps. Would like to know how to increase speed to other parts of the house.
- May 18, 2018
The wifi extenders are Netgear extenders, (outlet plugins) . Also using 'Amped Wireless' box to increase the bps on devices.
Testing is device using the extender.
michaelkenward
May 18, 2018Guru - Experienced User
How do you know that? What are you measuring the speed with?
What are the wifi clients on the receiving end of the wifi?
The router can spit out a squillion Mbps, but if your wifi receivers aren't up to it, they will never see that speed.
What firmware version do you have on the AC1450? A number is more useful than any vague "the latest" guesses. It may not be by the time people read this, and there can be newer versions, or "hot fixes", that do not show up in the browser interface.
