damani914
May 12, 2017Aspirant
How to increase upload speed?
I have the n750 router, my download speed is over 90 but my upload speed is about 3. I was wondering is there anyway I can lower the download speed to increase uploading?
- May 13, 2017
Contact your ISP and ask them.
damani914
May 13, 2017Aspirant
100 Mbps download speed, it says nothing about upload
TheEther
May 13, 2017Guru
- michaelkenwardMay 13, 2017Guru - Experienced User
And n750 could be one of any number of boxes.
Wifi speeds will not be the same as wired. You don't say which you want to improve.
Depending on the service, a 90 Mbps download speed should upload at something like 20 Mbps wired.
