goodguys
Jan 03, 2017Aspirant
How to install wireless router to AdTran equipment
Hi, CenturyLink completed the install of my dedicated T1 line in my home and have tested and verified internet access at the AdTran router. I want to install my new Netgear wireless router now w...
- Jan 04, 2017
up and running! plug and play.
thanks guys.
michaelkenward
Jan 04, 2017Guru - Experienced User
You can't break anything by trying yourself.
Manual and Quick Start guides are here:
WNDR4300v2 | Product | Support | NETGEAR
goodguys
Jan 04, 2017Aspirant
thanks! I'll see how it goes today.
I appreciate your response.
- michaelkenwardJan 04, 2017Guru - Experienced User
Pay attention to the order in which Netgear advises that you turn things on. It can be important.
- goodguysJan 04, 2017Aspirant
thanks guys.
- michaelkenwardJan 05, 2017Guru - Experienced User
Congratulations. You are clearly better at this stuff than you claimed.
Otherwise it would be a case of plug and pray.
