vijay_amrit
Dec 02, 2020Tutor
How to login to modem router configured to run as modem only
Hi, I have a C3000 modem + router which i was using as modem only for sometime. Now i want to enable its router function and i connected my laptop using a LAN cable. I am able to access internet, h...
- Dec 02, 2020
go to 192.168.100.1
vijay_amrit
Dec 02, 2020Tutor
Thanks. was able to login and configure the router. However realized why I had disabled it straight away. Speed over wifi drops few mins after router startup.
Dec 02, 2020Guru - Experienced User
Yeah, 2.4ghz is a slow band and sensitive to interference. If you're streaming/gaming/doing anything needing bandwidth, dual band is a must.
