n8smith
Jan 28, 2022Aspirant
How to make R6080 work better for devices further away
I have the AC1000 R6080 router and it works ok within ten feet but once I go about 10-20 feet around the corner to my office it sucks. My modem is fine, the router firmware is updated as well as the ...
Jan 28, 2022Guru - Experienced User
"tried resetting everything"
You tried factory resetting the router?
What firmware is on it?
what modem/gateway is it connected to?
What device are you testing on?
n8smith
Hi!
Yes I tried factory resetting the router by holding reset for more than 7 seconds.
What firmware is on it? The most updated one that's available
| V1.0.0.52 |
what modem/gateway is it connected to? modem is tplink and comcast says the modem is fine it must just be the router
What device are you testing on? i'm testing it on a windows laptop plugged into the router by ethernet
- plemansJan 28, 2022Guru - Experienced User
What tplink modem?
When you "go around the corner", what are the walls in the office made of? Certain material like concrete, brick, stone, metal all block wifi really well.
- n8smithJan 28, 2022AspirantDOCSIS 3.0 cable modem
And I think the walls are dry wall- n8smithJan 28, 2022AspirantBest Buy says xfinity is the best for my area and recommended a wifi 6 netgear router to try so I plan to try that (they said if that doesn’t work then the wifi 5 nighthawk should work). Xfinity tech person is coming tomorrow to see if there’s anything they can do as well but I assume I just needed the newer router
