Jno2
Jul 09, 2020Tutor
How to manage my R6400 router from PC. I don't want Nitehawk App on my phone.
How do I manage my R6400 router from PC. It used to be routerlogin.net, but no longer... I do not want the Nitehawk App on my (old) phone. What do I do? Thank you.
- Jul 09, 2020
if you're on windows
open a command prompt (click on start and type cmd)
type ipconfig and hit enter.
the default gateway address should be your routers address. This isn't always the case if you're in a double nat situation.
Jul 09, 2020Guru - Experienced User
You can log into it using the ip address of your router.
That's all I use for accessing mine.
Jno2
Jul 09, 2020Tutor
It was suggested I long in with the IP address of the router. How do I find that?
(using a PC)
- plemansJul 09, 2020Guru - Experienced User
- Jno2Jul 09, 2020Tutor
That got me the IP and I'm in.
Thanks.
