pdaalder
Jan 03, 2020Aspirant
How to provide good wifi coverage in a newly build house
Hello I've been spending a good evening digging into what product to buy to improve the wireless connection in my new house. The house is full of isolation materials and wireless connections ...
- Jan 04, 2020
pdaalder wrote:
I have no justification why but my preference is to have most of the communications over wire and have as little as possible to be wireless, or maybe I should say as short as possible.
I agree with that.
My justification is that wifi is more likely to suffer from interference and is easier to set up.
The reason for using Orbi is that it is simpler to set up and easier to manage. Apart from that it isn't miles apart from using a wifi router with repeaters added to fill any gaps in the wifi. But if you don't have gaps, a plain router is fine. But you have chosen one of the least capable.
michaelkenward
Jan 04, 2020Guru - Experienced User
Plug your details into product pages.
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
Wifi Router | Wireless Routers for Home | NETGEAR
Then check this place for comments and the usual review sites.
Where possible, use wired Ethernet to connect anything that does not move around. TVs, for example, are much easier to manage on Ethernet than Wifi.
pdaalder
Jan 04, 2020Aspirant
hi Michael
THank you for your answer. I did explore the mesh option, however I don't like the option of a device retransmitting information over the air to another device. Aside from this, the fact our house is extremely well isolated apperently results is very poor communication through the air.
My idea was to put a device that is connected over wire to the switch and that allows wireless devices to connect to it. That is why I had selected the product R6260 / AC1600 Smart WiFi Router Dual Band Gigabit (link), which is the product that your link (https://www.netgear.com/home/products/networking/wifi-routers/) to the wifi product pages also returned. However I also found a product named WAC124, which is not listed in the product page, but reading the characteristics does match my requirements.
What is the difference between the WAC and AC products?
Peter
