pdaalder's avatar
pdaalder
How to provide good wifi coverage in a newly build house
Hello   I've been spending a good evening digging into what product to buy to improve the wireless connection in my new house.   The house is full of isolation materials and wireless connections ...
  • michaelkenward's avatar
    michaelkenward
    Jan 04, 2020
    pdaalder wrote:
    I have no justification why but my preference is to have most of the communications over wire and have as little as possible to be wireless, or maybe I should say as short as possible.
    I agree with that.
    My justification is that wifi is more likely to suffer from interference and is easier to set up.
    The reason for using Orbi is that it is simpler to set up and easier to manage. Apart from that it isn't miles apart from using a wifi router with repeaters added to fill any gaps in the wifi. But if you don't have gaps, a plain router is fine. But you have chosen one of the least capable.
