mmoezzi
Mar 14, 2021Follower
How to retriece your stored ACCESS Admin password, if you have changed it and forgot it.
Hello Netgear Community,
Wanted to share with you all if you ever wanted to maybe connect from your mobile device or another laptop that you are try to connect either to the admin portal of your Cable Modem Router or the Netgear NightHawk App on your Andriod or iOS device and at one point logged into the portal and have save Cached Password on Chrome Browser then there is a way to retriece besides restting your device or trying to answer your retrieve password by those questions you setup.
So from the laptop that you have stored or cached your admin password:
* You can select the options (Customize or Control Google Chrome) section of your chrome Browser on far right side
* Then you will need to select Settings
* Then search and select the Auto Fill section and Select passwords:
* Next in the Auto Fill Password section search for 192.168.0.1 and look for username "admin"
* Next to the right that account name and hidden password an eye icon that has ***** start characters over it.
192.168.0.1 Admin ********* ((0))
* When you hover over it you can select "show password" and then type your computer password and it will show you your password then. :)
192.168.0.1 Admin password ((0))
No RepliesBe the first to reply
