lisareyes74
May 15, 2016Aspirant
How to see Attached Devices on Guest Network? Tenants are connected but do not show up.
Getting acquainted with the NETGEAR genie and was checking out "Attached Devices". I created a guest network on the 2.4 GHz connection for my tenants to use which they were successfully able to conn...
- May 23, 2016Thank you!
ElaineM
May 16, 2016NETGEAR Employee Retired
Hello lisareyes74
Welcome to the community!
It's possible that they have turned off their devices and that's why you're unable to see them.
All devices that are connecting to your router should show under Attached devices.
