jabbit1
Apr 20, 2022Follower
how to seperate 2.4GH & 5GH password WNDR3400v3
would like to know how to separate 2.4G & 5g password
Apr 20, 2022Guru - Experienced User
Simply log into the device and go to the wireless settings. From there you can change the ssid/password.
You can find the manual that goes over it here: https://www.netgear.com/support/product/WNDR3400v3
