mikeshick
Jan 05, 2021Aspirant
How to set up lan-lan cascade with Netgear R6300v2
I'm unclear how to set up lan-lan cascade with Netgear R6300v2. I have tried to leave internet as select automatically, and then changed the lan to be 192.168.0.2, while my main router, and therefor...
Jan 05, 2021Guru - Experienced User
both lan and wireless work in AP mode.
- mikeshickJan 05, 2021Aspirant
So, my steps are:
change the lan ip address as mentioned
turn off dhcp server
turn on wireless ap?
Do I need to have the same wireless broadcasts and/or passwords?
Is there any problem connnecting this to UDM as main router?
Thank.
- plemansJan 05, 2021Guru - Experienced User
Turning on AP mode, disables the dhcp server.
You can set them with the same ssid/password as the primary router but it won't be a seamless setup. Devices will tend to be sticky and stay connected to the wireless they initially connected to until it drops/becomes unusable.
I prefer to use different ssids in this instance.
- antinodeJan 05, 2021Guru
> [...] I want both lan and wireless, i think.
"LAN" = "Local-Area Network", and it includes wired and wireless
devices.> So, my steps are: [...]
Or, you could just employ a widely neglected resource:
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Wireless Access Point (AP)".> Do I need to have the same wireless broadcasts and/or passwords?
No.
If "UDM" is a router, then it should work.- mikeshickJan 05, 2021Aspirant
Thanks. Unfortunately, nothing including the manual helped me figure out what sequence I was supposed to take. I was running in circles trying to connect pc to ap, then router to ap, if wireless ap also provided lan ap....i spent about 8 hours on it and finally got it figured out. No manual, no right up worked that I could find.
if i recall, what worked:
UDM lan to Netgear wan
Netgear Lan to PC
modify Netgear Lan to 192.168.0.2
Netgear AP activated
Not positive, but think that worked.
