Camila
Feb 13, 2016Initiate
How to set up N900 WNDR4500v2 using MacBook Pro
Hi! I have a router that has been previously set up in my old house, and now need to make it work in my new apartment. The cables are connected, and it the network shows up on my computer, but interne...
- Feb 13, 2016
You can set up the router by connecting your computer to its Wi-Fi network.
Try pointing your browser at routerlogin.net. This should take you to your router's login page. If routerlogin.net doesn't work, then try entering the router's IP address into your browser. You can find the router's IP address address by holding down the Option key and clicking on the Wi-Fi icon on the top right of your Macbook screen.
You will need your router's admin password. Proceed to set it up to work with your new Internet connection.
TheEther
Feb 13, 2016Guru
