bark-dust
Dec 11, 2015Aspirant
How to set up wnr2020 as access point without
I have a wnr2020 that I would like to add to my existing LAN for wireless access out in the garage. When I go throught the setup pages on the Netgear Genie I don't see anywhere to set it up in acces...
- Retired_MemberDec 11, 2015
Almost any WIFI router can be made into a AP. Some include that option called AP Mode.... in the Netgear World..... while Linksys calls it Bridging. Seeing that your router doesn't offer the AP Mode you can follow this link.
http://routersetup.blogspot.com/2007/08/connecting-two-routers-wired.html
Retired_Member
Dec 11, 2015Almost any WIFI router can be made into a AP. Some include that option called AP Mode.... in the Netgear World..... while Linksys calls it Bridging. Seeing that your router doesn't offer the AP Mode you can follow this link.
- bark-dustDec 14, 2015Aspirant
Thanks searay.
