squawk1200a
Jan 21, 2022Aspirant
How to setup Netgear WNCE2001
 I am trying to resurrect an old Netgear WNCE2001 that someone installed for me on my Yamaha grand piano Disklavier about 8-9 years ago. I've got it plugged into power, an Ethernet cable into my lapto...
squawk1200a
Contrary to what the manual says, when I press the WPS button, the WLAN light does not turn amber or any other color. The LAN light is green but the WLAN light remains off.
Jan 22, 2022Guru - Experienced User
try factory resetting the wnce2001.
then when you connect a pc/laptop to it (disabe the wifi on that device) try to navigate to the mywifiext . net page
Not sure what device your trying to use but that adapter was approved up to windows xp. xp was the newest at that time.
So it might be a little futile to try to get to work.
A cheap wireless extender with ethernet port might be a faster/more stable option
- squawk1200aJan 22, 2022AspirantThanks. Tried the reset, same results. I guess I wish Netgear would put out some kind of "no longer supported, no longer works" notice on hardware that is too old to have it work correctly. This kind of dims my view of using Netgear products in the future based on this poor experience. - plemansJan 22, 2022Guru - Experienced User
 squawk1200a wrote:This kind of dims my view of using Netgear products in the future based on this poor experience.Your complaning because netgear hasn't updated a part that was made 12 years ago and was designed when windows XP was running. Even windows quits supporting OS's. You can't expect a company to update products that old. And I'm sorry, but I haven't seen any other networking company support devices that old either. And your description of the problem you're getting doesn't help much.
- michaelkenwardJan 22, 2022Guru - Experienced User
 squawk1200a wrote:
 I guess I wish Netgear would put out some kind of "no longer supported, no longer works" notice on hardware that is too old to have it work correctly. It does.The clue is in your "footer", the bit under your first message: Model: WNCE2001|Universal WiFi Internet Adapter|EOL The label EOL means End of Life. Not as clear as it might be, I agree, but it is there. In any case, it isn't a router so you aren't likely to get much help in a section given over to General WiFi Routers (Non-Nighthawk and Non-Orbi). Did you try this simple trick? Search - NETGEAR Communities – WNCE2001
