squawk1200a
Jan 21, 2022Aspirant
How to setup Netgear WNCE2001
I am trying to resurrect an old Netgear WNCE2001 that someone installed for me on my Yamaha grand piano Disklavier about 8-9 years ago. I've got it plugged into power, an Ethernet cable into my lapto...
squawk1200a
Jan 22, 2022Aspirant
Thanks. Tried the reset, same results. I guess I wish Netgear would put out some kind of "no longer supported, no longer works" notice on hardware that is too old to have it work correctly. This kind of dims my view of using Netgear products in the future based on this poor experience.
Jan 22, 2022Guru - Experienced User
squawk1200a wrote:This kind of dims my view of using Netgear products in the future based on this poor experience.
Your complaning because netgear hasn't updated a part that was made 12 years ago and was designed when windows XP was running.
Even windows quits supporting OS's. You can't expect a company to update products that old. And I'm sorry, but I haven't seen any other networking company support devices that old either.
And your description of the problem you're getting doesn't help much.
