Ravioli2022
Dec 09, 2022Follower
HOW TO SETUP QOS RULES ON R6080 using the smart wizard?
Hi I'm having issues with internet drops. I've identified the problem with the router. (connecting directly to the modem gives me a proper speed but it dropped immensely when using the wifi. I want...
Dec 10, 2022Guru - Experienced User
1. what modem/gateway is the router connected to?
2. the speed drop you're getting going from modem---->router? More than likely its because the R6080 isn't gigabit rated and is only 10/100mbps speed rated on its ethernet port speed. So if you're paying for faster than 100mbps service, you need to upgrade the router to something that supports those speeds.
