ScottG216's avatar
ScottG216
How to setup router as AP
I have a WNDR3700v2 that I want to use as an access point only.  I have an an Ubiquiti EdgeRouter-X (ER-X) that I'm using to load balance 2 internet connections.  I want the ER-Xto take care of DHCP ...
  • antinode's avatar
    Feb 13, 2019
    > I have a WNDR3700v2 that I want to use as an access point only. [...]
       Ok.
    > [...] I have the ER-X connected to the Netgear's WAN port. [...]
       Nope.  A wireless access point is all-LAN; it acts a as a network
    switch, with wireless capability.  The WAN/Internet port of the
    WNDR3700v2 is part of its router functions, and should be ignored.
       For one step-by-step, see:
          https://community.netgear.com/t5/x/x/m-p/1463500
    That's written for a C6300, but the steps are about the same for any
    other router (any make/model) which lacks a one-step WAP option,
    including yours.  But, other than the WAN/LAN port error, the rest
    sounds ok to me.
    > [...] Below are a couple screenshots [...]
       In-line images in these forums must wait for moderator approval, so I
    can't see yours yet.  (An attached file incurs no such delay.)  Some
    little description would be nice, even if the pictures were visible.
    Copy+paste is your friend.
