njfiddler
Jan 03, 2016Aspirant
how to setup WNDR3800 router as a bridge
I have a FIOS router, with an RJ-45 cable/jack to the room where I want to create a new wifi network for that part of the house. I got it to work, but the crucial step seemed to be when the Netgear c...
- Jan 09, 2016
Hi @njfiddler,
If that is the case, then you can setup the router in Wireless AP mode. You can do that by accessing the router's UI and go to Advanced > Advanced Setup > Wireless AP > Enable Access Point Mode > Apply. This will allow the NETGEAR router to be in the same network as the FIOS router and at the same time broadcasting a separate Wi-Fi for your devices to connect to.
Dexter
Community Team
njfiddler
I would like a separate Wi-Fi from the Fios one, that tends to be maxed out with gaming, etc.
I didn't try the wizard, do I needed to run that on a laptop connected to the netgear?
I haven't tried that, I assume you mean more than power cycle.
