njfiddler
Jan 03, 2016Aspirant
how to setup WNDR3800 router as a bridge
I have a FIOS router, with an RJ-45 cable/jack to the room where I want to create a new wifi network for that part of the house. I got it to work, but the crucial step seemed to be when the Netgear c...
- Jan 09, 2016
Hi @njfiddler,
If that is the case, then you can setup the router in Wireless AP mode. You can do that by accessing the router's UI and go to Advanced > Advanced Setup > Wireless AP > Enable Access Point Mode > Apply. This will allow the NETGEAR router to be in the same network as the FIOS router and at the same time broadcasting a separate Wi-Fi for your devices to connect to.
Dexter
Community Team
DexterJB
Jan 06, 2016NETGEAR Moderator
Hi njfiddler,
It is good to know that it is working now. When you mentioned you wanted to have a separate Wi-Fi, did you mean having an entirely separate network from the FIOS (devices connected to the FIOS will not be able to communicate with the devices connected to the NETGEAR) or just a separate wireless signal yet still within the same network as the FIOS (devices connected to either the FIOS or the NETGEAR will be able to communicate)?
Dexter
Community Team
njfiddler
Jan 07, 2016Aspirant
I would like devices on the Netgearwifi to be able to reach devices on the FIOS wifi, in particular the printer. I just tested it, and right now that isn't working.
- njfiddlerJan 07, 2016Aspirant
P.S. However, the higher goal is to partition the traffic so when the FIOS wifi is maxed out, the Netgear can still get its share of the overall internet connection. If that means not being able to reach the printer, so be it. I hope I'm making sense.
- DexterJBJan 09, 2016NETGEAR Moderator
Hi @njfiddler,
Dexter
Community Team
