njfiddler
Jan 03, 2016Aspirant
how to setup WNDR3800 router as a bridge
I have a FIOS router, with an RJ-45 cable/jack to the room where I want to create a new wifi network for that part of the house. I got it to work, but the crucial step seemed to be when the Netgear c...
njfiddler
Jan 07, 2016Aspirant
P.S. However, the higher goal is to partition the traffic so when the FIOS wifi is maxed out, the Netgear can still get its share of the overall internet connection. If that means not being able to reach the printer, so be it. I hope I'm making sense.
DexterJB
Jan 09, 2016NETGEAR Moderator
Hi @njfiddler,
If that is the case, then you can setup the router in Wireless AP mode. You can do that by accessing the router's UI and go to Advanced > Advanced Setup > Wireless AP > Enable Access Point Mode > Apply. This will allow the NETGEAR router to be in the same network as the FIOS router and at the same time broadcasting a separate Wi-Fi for your devices to connect to.
Dexter
Community Team
