grillmaster77
Dec 09, 2021Tutor
How to setup WNR3500L as second router for seamless wireless network extension
I have an xfinity cable modem as my primary router. wireless SSID WiFi2.4 channel 6 gateway IP is 10.0.0.1 DHCP starts at 10.0.02 I have a WNR3500L connected to the main router, also with a 2....
- Dec 10, 2021
Make and model?
I have a WNR3500L connected to the main routerAn ancient (2009) device with less than startling wifi that can't hope to be "seamless". (That's what Mesh technology does.) But it could extend the wifi range.
It seems it should be possible to do what I want. Any suggestions on what to try?It is called wireless access point (AP) mode. But your device seems to predate having that "built in" to the configuration, so it may not come with an easy "switch" to get it into AP mode in the browser graphical user interface (GUI). But you could try this:
How to turn an old Wi-Fi router into an access point - CNET
The problem is that devices connected to one router are invisible to devices connected to the other. For example, we have several devices that you can cast to, like Chromecasts, TVs, etc. However, because of the two networks, you can't always see the device you want to.
Probably a consequence of "double NAT":
What is Double NAT? | Answer | NETGEAR Supportand
How to fix issues with Double NAT | Answer | NETGEAR Support
michaelkenward
Dec 10, 2021Guru - Experienced User
Make and model?
and
