Cstein13
May 30, 2023Aspirant
How to track WiFi outages
Is there a way for me to track when my WiFi router or modem stop working?
michaelkenward
May 31, 2023Guru - Experienced User
You don't say which Netgear device you own, but most routers log various events.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
Check the section in the manual View Logs.
Cstein13
May 31, 2023Aspirant
It is a R6120 AC1200 Dual Band WiFi Router. I tried to log into it and it doesn’t show me anything past a few hours. If there’s any tips it would be much appreciated
