martind1111
Sep 29, 2021Aspirant
How to troubleshoot a dead R6250
I have been using a Netgear R6250 router for several years and yesterday, it stopped working. All lights are off. I have verified that the power supply registers 12V. Not sure if there is anything I ...
martind1111
Oct 10, 2021Aspirant
Thanks for your response. I unfortunately do not have a matching power supply. I did try to power on/off many times to no avail. Not much I can do at this point but replace it.
Oct 10, 2021Guru - Experienced User
have you checked the power supply? Just to see if its appying voltage at all?
