chris0321
Apr 12, 2023Follower
How to turn off Smart WiFI
I had to contact Optimum support. I contacted via chat. I asked if I could disable Smart WiFi. I was put on hold for about 40 minutes before I was transferred. After being transferred, I was told dis...
Apr 12, 2023Guru - Experienced User
What actual device do you have?
some devices you can disable it and others you can't. So it helps to know.
And I'm not sure why you contacted Optimum for help with it versus netgear.
