deeboy's avatar
deeboy
Follower
Jan 26, 2021
how to turnoff firewall of the orbicable modem router model CBR750
1 Reply
  • > how to turnoff firewall of the orbicable modem router model CBR750
       What "firewall"?
       General advice: You might have more success if you described the
    actual problem which you are trying to solve, rather than asking how to
    implement some particular "solution" ("turnoff firewall"), which may
    have little or nothing to do with the actual problem (whatever it might
    be).
       What did you do?  What happened when you did it?  As usual, showing
    actual actions (commands) with their actual results (error messages,
    LED indicators, ...) can be more helpful than vague descriptions or
    interpretations.
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Read.  Look for "firewall".
    Further reading might not hurt, either.
