DeniseLincoln
Jan 05, 2019Aspirant
How to update firmware
Netgear AC1200 Model R6120
Trying to update firmware on a Mac WITHOUT USING A PHONE APP.
Can download the file
R6120-V1.0.0.46.img
Can't get any farther.
The file doesn't open when double c...
- Jan 05, 2019
> The file doesn't open when double clicked. [...]
That's not how it's done. Normally, at this point, I'd suggest
reading the Release Notes file for instructions, but...
> [...] The Notes the come with it are just a link to download the same
> file again. [...]
Those Release Notes are worse than usual (and usual is none too
good). Typically, the Release Notes file will include actual
instructions.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Look for "Update the Firmware
of the Router" and "Manually Upload New Firmware and Update the Router".
Ignore the part about ".chk", and pretend that it said ".img". (The
hits just keep on coming...)
> [...] None of the instructions I've found elsewhere on the Netgear
> site seem to be of any use. [...]
The non-psychics in your audience may have little idea of where you
might have looked, or what you might have found there.
antinode
Jan 05, 2019Guru
> file again. [...]
instructions.
- DeniseLincolnJan 07, 2019Aspirant
Thanks very much. It worked.
Denise
