Alaska34
Nov 15, 2022Aspirant
how to update firmware
Alaska34
Thank you but I think I am too old and stoopid to even be asking for help.
- FURRYe38Nov 15, 2022Guru - Experienced User
What NG product are you needing help on?
Is this a router, modem? Picture display?
There are gentlemen in this forum that are around 20 years my senior. đ
- Alaska34Nov 15, 2022Aspirant
Its a router model R6250 and it is out of warranty.
I don't often use the old lady card but technology scares me.
- plemansNov 16, 2022Guru - Experienced User
Here's a written guide on doing it manually:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
and then a video guide at the bottom of this KB article:
https://kb.netgear.com/23442/How-do-I-update-the-firmware-on-my-NETGEAR-router-with-a-web-browser
Do you know what firmware version you're on? A lot of devices automatically update.
Also, is there a reason you think you need to update? Just checking if you're having a problem or what's going on exactly.
