Geoff206
Jan 20, 2018Aspirant
How to upgrade firmware on DM200 with WNR1000v3
Hello All, I have a DSL Netgear modem (RM200) and want to upgrade its firmware. I also have a Netgear wireless router (WNR1000V3). When I go to routerlogin.net, I only see the wireless router. ...
- Jan 20, 2018
> [...] When I go to routerlogin.net, I only see the wireless router.
"routerlogin.net" (or one of its friends) generally works if you're
connected directly to the target gizmo. Which you're not.
> I have seen on other posts that you should be able to access the modem
> using 192.168.0.1, but that does not work for me.
Did you try "192.168.5.1"?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. (Or, look for
"192.168.".)
antinode
Jan 20, 2018Guru
"192.168.".)
Geoff206
Thanks! That did the trick.
