Lewey
Apr 30, 2021Follower
HP 2548 Printer will not hook up.
HP 2548 will not hook up to the Orbi
1 Reply
"will not" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
You seem to be trying to connect your mobile device directly to your
printer, not your printer to your "the Orbi" (router). 'the network
"HP-Print-74-Deskjet 2540 series"' is your printer; nothing to do with
your router.You might want to exploit an under-appreciated resource:
https://en.wikipedia.org/wiki/RTFM
Visit hp.com , and get some documentation for your printer. Read.
Follow the installation instructions which you find there.
