Janboeg
Nov 04, 2022Follower
Hp 4100 not connecting to network
Any suggestion to get HP printer connected to network?? Says that network (orni 50) does not work and installation can nor be completed
1. what router/network are you connecting it to? you didn't put what netgear router you have.
2. did you contact HP for help setting up your device?
Janboeg wrote:
Any suggestion to get HP printer connected to network??The usual way to fix wifi printers (if that is what you have) is to find the printer maker's utility, the software that runs on your operating system. Then use that to connect the printer to the wifi.
Installing HP wireless printer software | Wireless Printing Center | HP® United Kingdom
The router just broadcasts wifi. It is then down to the printer to play ball. There isn't much that you can do on a router, beyond fixing it to a particular IP address, that affects what the printer gets up to.
Where possible, using the WPS feature can simplify things.
