xzab711
Sep 27, 2016Aspirant
HP Printer USB not recognized
Hi, I've gone through tons of manuals and help files and I cannot get my printer to show on the network. Here's the details:
- I've connected my HP PSC 1315 printer via USB 2.0 Cable (supported by printer and apparently this router) to the USB Port on my router
- The USB light never lights up on the router when printer is connected
- I am on a Mac, latest OSX 10.11
- I installed the printer driver on my mac
- I installed the Genie software
- I browsed to my router url and cannot see the USB printer (or any devices) in "Advanced > USB Settings".
- I tested the printer before hand with the USB cable directly to my mac and it worked fine, I can print.
- I can see the printer in the genie app, but only when it was connected directly to my computer via USB. Once I connect the USB back to the router, printer shows offline.
- I tested the USB port on the router with a regular USB storage device and it worked fine and I COULD see that in the router USB settings -- so we know the USB port works.
So what could I be missing here? any help is much appreciated! Thank you!
Hello @xzab711
Welcome to the community!
As of this writing, El Capitan is not compatible yet to work with ReadyShare Print.
You may try to use Bonjour to print.
How to configure a network printer using Bonjour in Mac OS X
- ElaineMNETGEAR Employee Retired
Hello @xzab711
- xzab711AspirantAh ok thank you!!
You're welcome.
