jjhaigh
Jul 12, 2016Aspirant
HTTPReadySHARE cannot be opened because of a problem
Hi everyone How the heck do I get rid of this annoying piece of software (which I don't even use!!) from my iMac, which generates an error message roughly once an hour saying that HTTPReadySHARE ...
- Mar 16, 2017
We have officially released the compatible software to work with Mac OSX and above.
ElaineM
Jul 28, 2016NETGEAR Employee Retired
By the way, have you tried reinstalling and then removing it again?
- wood92Oct 21, 2016Aspirant
I have same issue. I still use my Netgear WNDR 4500 router and it works fine but a year or so ago these same warnings started popping up on my computer. I uninstalled my Readyshare app and don't really have a need to reinstall it as I don't use a ReadySHARE printer or attached USB devices. Has anyone found any answers other than a reinstall to make this go away.
Also, the ReadySHARE Printer download says it only supports MAC OS 10.9 but I'm on 10.11.6. Would it be a waste of my time to reinstall?
- ElaineMOct 25, 2016NETGEAR Employee Retired
wood92 The USB Control Center Utility is not available yet to work with the El Capitan and newer Mac OS.
You may want to see the thread from apple regarding the error.
https://discussions.apple.com/thread/4207127?start=0&tstart=0
- wood92Nov 07, 2016Aspirant
Yeah You Right!
After a year of the pop-up and months of googling for tips this link finally solved my problem.
