JohnstonJacob88
Jan 31, 2023Tutor
Hulu/Disney+ not working on Nighthawk R6400v2
Hello! A few weeks ago I transferred my spectrum Wifi network from my roommates name into mine (using the same router and modem as before) and now disney+ and Hulu both won’t work on ANY device connec...
- Feb 01, 2023
Either way, glad its working!
Should mark it solved so others aren't still trying to fix it still 🙂
Jan 31, 2023Guru - Experienced User
What error does it give you?
When you switched services, did you factory reset and start over?
Have you tried changing dns providers?
Try a different DNS Server. Here's a few for ipv4. Also remember to change the ipv6 dns server if ipv6 is enabled
CloudFlare 1.1.1.1 and 1.0.0.1
GoogleDNS 8.8.8.8 and 8.8.4.4
JohnstonJacob88
Jan 31, 2023Tutor
Hulu gives me P-dev313 on my TV and P-dev314 on my phone. Disney just says it can’t be accessed but I’m more so concerned with Hulu. How do I change DNS? Thank you!
- plemansJan 31, 2023Guru - Experienced User
what modem/gateway is the router connected to?
What speeds are you paying for?
What device is it thats having issues?- JohnstonJacob88Jan 31, 2023TutorOk so worth noting it’s not a nighthawk it’s actually an AC1750. It is connected to what I believe is a netgear CM500 modem. Currently doing just basic Spectrum internet.
- plemansFeb 01, 2023Guru - Experienced User
here's how to change dns.
https://kb.netgear.com/30510/How-do-I-set-static-Domain-Name-System-servers-on-my-NETGEAR-router
