enichante
Feb 17, 2022Follower
I am trying to decide between two Netgear routers.
Costco has the NETGEAR Nighthawk 6-Stream AX4300 for $130, down from $200 right now. It says it's wifi six but the details show up to 802.11 ac Is this some sort of strange advertising issue? I'...
Feb 17, 2022Guru - Experienced User
Are you referring to this model router?
https://www.netgear.com/support/product/rax45.aspx
It supports AX modes, along with older wifi modes like AC and N.
DNB09876
Feb 18, 2022Aspirant
DNB= do not buy this crap. 2 years old, and they are done with you…after the first 6 months of purchase. They give you no customer service they give you no ways to fix things they just cut you off. Just saying messages will be after learning the hard way do not buy their crap!
- FURRYe38Feb 20, 2022Guru - Experienced User
Other router mfrs have similar warranty policies.
