Alpha1991
Nov 04, 2022Aspirant
I bought a used Router R1000
It didn’t came in with a serial number let alone any information. It was good to be true, but I can’t access the router. How can I change the password or username with this used router. 😞
It works I just have no information to set it up
1 Reply
I can't find anything called R1000 in the Netgear system.
It was good to be true, but I can’t access the router. How can I change the password or username with this used router. 😞First, as this is a used device, reset it.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
