broman42
Nov 16, 2020Follower
I can not find my WIFI Name
I can not find my wifi network when trying to conect my tv to the wifi.
michaelkenward
Nov 17, 2020Guru - Experienced User
Are you using the TV's set up routine to connect?
Can other devices find the wifi?
What is this TV?
By the way, a wired connection is usually best. Wifi can be hard to set up on many TVs and often unreliable.
If you can't plug the TV into the router, then Powerline Ethernet can be a great alternative.
