Tomscomputer
Oct 12, 2017Follower
I can not log in to my router it will not allow me to log in. it does not recognize my log in or ans
I can not log in to my R6400 router, it will not allow me to log in. it does not recognize my log in or answers to any of the security questions. Thanks for any help. Tom
- Oct 13, 2017
antinode
Oct 12, 2017Guru
If the expected credentials don't work, and the default values
("admin" and "password") also don't work, then the usual suggestion is
to do a full ("factory") reset, and then reconfigure the router.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. The User Manual should explain the procedure.
