SpecialFX4U2C
Nov 30, 2016Aspirant
I cant access router login page or internet Nighthawk R8000 or R9000
So i used to use N Hawk R8000, about a year ago i stoped using it still worked but i went to modem only for personal reasons, forward to last week i went and tried to connect the N hawk R8000 and all...
- Dec 02, 2016
Yes! Yes! it worked, thank you so much sir for taking time to help me, you guys are the best over there at Netgear.
SpecialFX4U2C
Dec 01, 2016Aspirant
Tried that suggestion but still no luck.
TheEther
Dec 01, 2016Guru
Is your computer configured to obtain it's IP address automatically? Can you check that it's getting an IP address? Can you see what the default gateway is?
- SpecialFX4U2CDec 01, 2016Aspirant
If its the one on top Default Gateway - it reads - fe80::201...........
If its the one on the bottom Default Gateway - its blank there is no IP, no numbers.
This is through the modem connection right?
- TheEtherDec 01, 2016Guru
No. We're trying to get you to log into the router.
Did you connect a computer to one of the router's LAN ports? Does your computer run Windows, OSX or something else?
