Jiraporn
Apr 09, 2017Aspirant
I can't log in my router
my friend wants me to solve a problem with low signal. She recommended to log in to router, but I can't. please suggest me. It said you are not connected to your router's wifi network.
- Apr 11, 2017
I don't know. But I copied link to router log in page again, it worked.
schumaku
Apr 09, 2017Guru - Experienced User
Hi,
Lack of any details of your router, or what you have already tired - check these:
Why can’t I access routerlogin.com or routerlogin.net?
If you cannot login to your router
How do I locate my router’s IP address?
-Kurt
michaelkenward
Apr 10, 2017Guru - Experienced User
The usual destinations are:
http://www.routerlogin.com/
and
http://www.routerlogin.net
If they don't work, then the IP address might be an option. Here the usual suspects are:
http://192.168.0.1
or
http://192.168.1.1
And if this really is a router, what modem is it attached to?
